I
Ian Sutherland
Hi folks, at my daughters new home today, installing odds & ends & she
asked me to install an "Electronic scale remover". Being a skeptical
person, I had a look at this device ($500.00) & decided not to instal
it until I knew more about it. Hopeing that someone reading this will
be able to prove me wrong & tell me that it really does work. It is
suposed to remove scale & prevent it's reformation in pipes, valves,
plumbing, hot water systems etc. It consists of a plastic box,
plug-pack & some hook up wire to wind around a water pipe. The wire is
wound around a water pipe for 25 turns, then along the pipe for 100 to
150 mm then another 25 turns in the same direction then back to the
unit. The plug pack is 12 Vdc @ 500 mA. The box has a well made p.c.b.
with a voltage reg. a couple of LM358N's 2 transistors & a 16 pin I.C.
that has had the type No. removed by abrasive paper & some passive
components. Having 2 coils of wire wrapped around the pipe would seem
to me to be using some form of magnetic field, but the instructions
say "Applicable to all pipes, Copper, Ferrous & Polymer pipes" I would
have thought that with the power levels available, there wouldn't be
much of a field inside a ferrous pipe.
Not wishing to disparage any organization, I would be interested to
hear comments from anyone who has used, come accross or knows anything
about these units. I hope that I can be convinced that it does work.
Cheer's, Ian Sutherland.
