sms controled home appliances
Discussion in 'LEDs and Optoelectronics' started by kunal balwani, Jun 30, 2012.
  1. kunal balwani
    kunal balwani
    Jun 30, 2012
    hi!
    i want to make a project on "sms controled home appliances".....plz help in selecting the right module or a ryt device to use in this project....
  2. CDRIVE
    4,960
    651
    May 8, 2012
    I searched "SMS" and it returned Text Messaging. So, are we talking about a device that takes commands via decoding received text?
  3. kunal balwani
    kunal balwani
    Jun 30, 2012
    yes
    yes .....some1 sugested me for sim300....but this device do many more functions & it it complicated too.....
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    And you think developing your own is going to somehow be easier? You need cellular connectivity, and a GSM/GPRS module like the SIM300 is what you are going to need, that is unless you have the skills to build your own cellular connectivity module...
    This isn't going to be an easy task, it's not stupid complicated either when using a cellular module to do all the heavy lifting, leaving you with just building/coding a device to read the messages and click the appropriate relays... But, it's not something someone with no knowledge is going to be able to accomplish without a steep learning curve...
    It's a whole lot easier to interface a DTMF module into an over the counter phone with an auto answer circuit... A simple call to that phone and a few DTMF tones later you are up and running... I can see an inexperienced person actually being able to accomplish this with a little hard work... That and the fact there is a ton of info about using DTMF to do just this...
  5. CDRIVE
    4,960
    651
    May 8, 2012
