SMPS power supply
Discussion in 'Power Electronics' started by electronicsLearner, Mar 25, 2015.
  1. electronicsLearner
    electronicsLearner
    11
    Mar 25, 2015
    Hi everyone,
    I have a SMPS which is powering my micro controller. The power supply is 24V and i am reading the same power supply voltage using micro controller by giving to one of the ADC channel. My doubt is i am reading the power supply voltage at every 1ms and when i plot my adc count i find that the voltage periodically goes to around 3v and then back to 24V. Does SMPS mean the voltage will be repeatedly going from OFF to ON. Am i reading the RC time constant before the power supply is stabilized. please help.
    regards,
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Can we see a circuit diagram please.
    Adam
  3. electronicsLearner
    electronicsLearner
    11
    Mar 25, 2015
    sorry it is my mistake, programming problem in S12x micro controller where in two cores (xgate and s12x) are available one core is updating the adc data of the voltage the other is trying to read at the same instance, hence there is data corruption at some points of the collected data and the value shows very less value than the actual value.
  4. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    Try to add additonal load to its dc output. Just to islolate problem.
  5. shumifan50
    shumifan50
    548
    56
    Jan 16, 2014
    The ADC logic should determine when you can read the value, it cannot just be read every 1 ms as you might read while it is charging.
  6. electronicsLearner
    electronicsLearner
    11
    Mar 25, 2015
    But how do i know when to read as the battery charging may take different times in different conditions?
  7. shumifan50
    shumifan50
    548
    56
    Jan 16, 2014
    Read the datasheet, I don't have the time right now to fish out the details, but there are flags that get set that tell you when you can read the values. Look at the sample code in the data sheet.
  8. electronicsLearner
    electronicsLearner
    11
    Mar 25, 2015
    Ok i will read the data sheet, thank you very much for the information.
