Smps Nonlinear Carrier Controller
Discussion in 'Electronic Design' started by D from BC, Mar 8, 2007.
  1. D from BC
    D from BC Guest
    I found this on:
    http://ece-www.colorado.edu/~maksimov/apec98-3.pdf
    It's on page 7 and a large signal model on page 9.
    The benefit is no power stage damping.
    How does a smps nonlinear carrier controller work?
    Can anyone spare a nonlinear carrier controllers for dummies
    explanation?
    Or a link to some better reading.
    D from BC
  2. Terry Given
    Terry Given Guest
    yeah, Dragan did, in an older paper ;)
    IEEE trans power electronics, alas cant remember which one.
    heres an example. Run a DCM flyback converter from a full wave rectified
    supply (no cap).
    run it at constant on time
    know Vin = Lp*dI/dt
    dt = constant
    Lp = constant
    dI = Vin*(dt/ton) = K*Vin
    so input current peaks follow |sin| envelope. voila, control-free PFC
    the NLC method uses an analogous approach. write down the equations for
    input current as a function of Vin, D then solve for D
    Cheers
    Terry
  3. D from BC
    D from BC Guest
    Thanks for the kickstart... :)
    D from BC
  4. Terry Given
    Terry Given Guest
    If I run across the paper I'll post the reference. Im just too lazy to
    scan thru a gazillion professional comics :)
    Cheers
    Terry
  5. Fred Bartoli
    Fred Bartoli Guest
    Terry Given a écrit :
    IIRC the paper is in the same directory, which is (was) browsable (???).
