Jumbaliah
Hi, I've got a dead powersupply from a JVC VCR (HR-S4700U, pwrspply #
PB10559). I've replaced the electrolytic caps last year and recently
it came to a dead stop.
I opened it up and noticed that there were some scorch marks on two
caps due to heat from two power resistors (R8 - 220ohm and R13 -
180ohm). These resistors are in series between the base of Q1 (C4161
NPN high speed switch in TO220) and the collector of Q2 (C3616 NPN
high gain switch TO92).
What I found strange is that these resistors are bypassed with a trace
that goes from the base of Q1 to the collector of Q2. But the
resistors must form a type of voltage divider because there is a tap
taken between the resistors that leads to some other components and
into a Sharp PC817 photo transistor and also into one of the primary
inputs on the large transformer.
I thought that maybe R8 or R13 were blown but I removed both and
measured them and they have resistance close to their rated value.
Does anyone have some tips for me that would explain why R8 and R13
would see so much current they'd blacken some neighbouring caps?
Jumbaliah
Jumbaliah
