TP said:
Thank you John. The P/N is LTC 1871. SEPIC topology similar
to the example of page 29 of the data sheet except that there is
a MOSFET driver inserted in the gate drive line. Input is 10-35V,
tolerant to 100V. Output is 12V @ 4A. L1,L2 is a dual 22uH
toroid.
http://www.linear.com.cn/pdf/1871fas.pdf
Many questions come to mind, not the least of which is how you
tolerate 100 volts in, when the chip has an absolute input voltage
rating of 36, but never mind, for now.
The biggest problem with designing a reliable circuit with this chip
is the unspecified gm of the error amplifier (650 umho typ., no max.
or min.) So no matter how much gain the error amplifier has, from
zero to infinity, it meets data sheet specifications. But this gain
is an integral part of the design for stability. Can you post a
layout of your board that shows how the input and output filter caps
and source of M1 relate to the common pin on the chip and the feedback
divider connections? Trace inductance and resistance and capacitor
ESR can be major players in the noise that sees its way to the error
amplifier. The error amplifier input node (pin 3) is also quite
sensitive to capacitive pickup, if not shielded by the layout. It may
be helpful to parallel the resistive divider with a capacitive divider
to lower this node's impedance (divide capacitive coupling) at high
frequencies.
Another big variation in the gain and stability of the current control
is the resistance of the fet switch. The lower this is, the higher
the effective gain of the current control loop. In the extreme, if
the resistance of the switch approaches zero, the gain of the current
control loop approaches the open loop gain of the current sense
comparator. Yikes. That is a big drawback of using the fet
resistance as current shunt, instead of having an actual, known
resistance in the source lead as a shunt.
This chip gives me heartburn just looking at the data sheet. It is
optimistic enough to have been designed by a digital designer.
