SMD Identification
Discussion in 'General Electronics Discussion' started by kcardona86, Apr 5, 2014.
  1. kcardona86
    kcardona86
    9
    Apr 5, 2014
    Can anyone help me identify the component in this image please
  2. (*steve*)
    25,477
    2,820
    My guess would be it's an oscillator module or maybe a mosfet.
    Having some understanding of the device it's in and what's around in on the board might yield a little more information.
  3. kcardona86
    kcardona86
    9
    Apr 5, 2014
    Well this component is based on a Macbook pro retina laptop, one of these has exploded after a liquid damage. and there are too many to be an osc lol
  4. kcardona86
    kcardona86
    9
    Apr 5, 2014
    This is an overview of the board
  5. (*steve*)
    25,477
    2,820
    Yep, they're more likely to be power mosfets, especially as they're close to inductors and diodes.
    Do they all have the same part number?
  6. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Metal can MOSFETs. That's what they are. Steve your right and the big square things are most likely 0.36uH inductors
    Adam
  7. kcardona86
    kcardona86
    9
    Apr 5, 2014
    It seems that all of them in that area have the same number except the one that concerns me which is "1010 CDZM 1244".
    does it make sense to you ?
  8. (*steve*)
    25,477
    2,820
    Yeah, and on closer inspection that's an International Rectifier symbol on the first line.
    IRF1014?
    If so, I can't find any datasheet.
    edit: IRF1010? And the rest would be date code and assorted ephemera (perhaps)
    datasheet (but note it's not in the same package and I would consider it only speculation at the moment.
  9. kcardona86
    kcardona86
    9
    Apr 5, 2014
    Thanks guys for your help, I will post any links or datasheets as soon as I find it for your info ;)
    A least I have a starting point :)
  10. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Looks like their MEDCAN or SMALLCAN. It might be a special because I can only find that package in the directFET range.
    Adam
  11. kcardona86
    kcardona86
    9
    Apr 5, 2014
    By any chance do you know how to restore faded ids on these type of components ?
    Kris
  12. (*steve*)
    25,477
    2,820
    They may not be faded, they may be deliberately defaced to ensure you can't replace them yourself.
  13. kcardona86
    kcardona86
    9
    Apr 5, 2014
    After a good afternoon searching for this device , I found that its reference designator is Q7510 and it is an IRF6802SDTRPBF MOSFET 25V Dual Control FET
  14. (*steve*)
    25,477
    2,820
    Are you sure? The pad layout looks different. datasheet
    How did you come to the conclusion it was this part?
  15. (*steve*)
    25,477
    2,820
    It might be worthwhile reading the resistance between the pairs of pads at each end to confirm that they are shorted.
  16. kcardona86
    kcardona86
    9
    Apr 5, 2014
    Also the FET had burn marks around it and it physically looks damaged
