SMD Device Marking Code
Discussion in 'Datasheets, Manuals and Component Identification' started by davidge, Sep 2, 2011.
  1. davidge
    davidge
    Sep 2, 2011
    Does anyone know what is the device that has marking "LAC" on it? It is SOT23-5 package.
    David
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
  3. (*steve*)
    25,473
    2,819
    My information suggests is could also be an RP171N591B (5.9V 150mA)
    http://www.dz863.com/datasheet-8205207663-RP171N591B_150ma-10v-Input-Ldo-Regulator/
    or even an XC6219A432MR, which is a 4.3V 240mA reg. It's also on an sot-25 package which appears to be similar...
    Since they're all LDO regulators, you can probably get a good indication of which is the most likely from the input voltage. ...And from the way they are connected in the circuit.
  4. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    The RP171N591B as a 5 digits marking. LAC + 2 digit for the lot number
    The XC6219A432MR as a 4 digits marking.1 L digit marking for the product serie + 2 digits for the voltage + 1 digit for the lot number.
    cheers,
    Olivier
  5. (*steve*)
    25,473
    2,819
    Your information sounds better than mine :)
    What is your source?
  6. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
  7. (*steve*)
    25,473
    2,819
    No, what I meant was, what is your source for the cross-reference information between case markings and devices?
  8. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Steve,
    misunderstanding on my side. In fact I just Google it. With LAC SOT23 query it's the second result. I find this is better than dedicated tools as it also drill inside datasheets and it's more up to date. But at the end you find more candidates than me ! :)
    Olivier
  9. (*steve*)
    25,473
    2,819
    I should add that to the sticky thread!
  10. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Sure, it will help to promote this Californian start up company :D
