Smallest IR Receiver
Discussion in 'Electronic Design' started by Dirk Bruere at NeoPax, Dec 13, 2006.
  1. Looking for whatever is the smallest integrated IR receiver for r/c at
    38kHz.
    Problem is that even the Sharp GP1U series is too big.
    I'm looking for something the size of a 5mm LED.
    Does anything like this exist?
    Dirk
  2. default
    default Guest
    Sure do
    IR receiver for R/C? you mean IR/C?
    Check this out
    http://www.bgmicro.com/pdf/page11.pdf
    940nm infrared receiver. The center carrier frequency is 38kHz. It can
    see horizontally and vertically at a 45 degree angle. 5Vdc-TTL and
    CMOS compatible. Low power consumption-1.2 to 5mA. Photo detector and
    preamplifier in one package. Improved immunity against ambient light.
    Complete Specs at www.bgmicro.com. LED1130.....
    These are turning up in several electronics surplus outlets.
  3. default
    default Guest
    http://www.bgmicro.com/pdf/led1130.pdf
    complete specs - 7 mm X 8 mm
  4. Looks identiucal to the Vishay parts ( e.g. tsop34837)
    Vishay also do a SMD variant, TSOP36237, whch is smaller in some dimensions, but not much.
  5. Luhan
    Luhan Guest
    The Vishay parts work very well....
    http://members.cox.net/berniekm/remoteir.html
    Luhan
  6. The GP1u series has long been obsolete so don't design it in. The
    replacement is the same as the American opto device above. I wouldn't use
    this- noise immunity. The metal can version is much better. I can't tell you
    what the sharp part number is. The supplier in the UK puts their own number
    in their catalogue- HMV602 ( H or V). It works very well. package size is
    about 7mm sq. x 3mm.
    I don't think you'll get an integrated IR detector the size of a 5mm
    led.....
  7. Thanks for the help guys.
    Dirk
    http://www.onetribe.me.uk - The UK's only occult talk show
    Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4
    http://www.resonancefm.com
  8. Ross Herbert
    Ross Herbert Guest
    As others have pointed out, the modern IR receivers are all marginally
    wider and higher than a 5mm led, but not by very much. Overall the
    space requirements for a 5mm led and a IR reciever is about the same
    in practical terms.
    In addition to the American Micro products there are numerous asian
    made items such as the Brightled BRM1030
    http://www.brightled.com.tw/Downloads/Products/Receiver_Moudule/BRM-1030.pdf
