sciencetoolbar
- Apr 10, 2017
- 29
- Joined
- Apr 10, 2017
- Messages
- 29
Things I used to create the generator in this movie:
3V Dc motor + plastic stalk ( inside “2 function toy” cars both parts; plastic stalk is used to fix the case of the toy car – the screw entrance in the plastic stalk)
7w AC led light bulb+ E 27 socket lead+ wires
3,7 v - 600 mah Li-Po battery ( mini drones)
Neodymium magnet sphere diameter 12.7 mm + neodymium magnet screw thread (you need just the metallic case – remove the neodymium magnet from inside)
Copper coil (inside microwave oven turntable motor)
Construction kit (toys) plastic and metal–used for the coil and the 3v dc motor holder
Power switch.
Important observations regarding simple generator:
1. the angle between the coil and the rotating sphere it is a must otherwise the output voltage will be low
2. The position of the neodymium sphere magnet on the metallic case is a must otherwise the output voltage it will be low (“metal socket”) N-S – I establish the position with a small iron screw.
3. I used nonmagnetic materials for the coil holder area otherwise the magnetic components will influence, in the bad way, the rotation of the sphere (like a magnetic brake+ the attraction force )
Notice: using different types of DC motors, copper coils, batteries, neodymium magnets we obtained different voltages
we wish to improve the small generator educational purpose waiting for ideas
thx science toolbar
Power switch.
thx science toolbar
