Sludge Blanket Levels?
Discussion in 'Electrical Engineering' started by BIGEYE, Jun 7, 2006.
  1. BIGEYE
    BIGEYE Guest
    Has anyone had success in measuring sludge blanket levels in Picket Fence
    Thickeners as used in the waste water industry?
    I have tried single point level detection using light, very little success
    with this, and quite often the sensor gets caught in the rake. I am now
    using ultrasonic and getting better results. This way I get a continuous
    level measurement. However, blanket level detection is sometimes unreliable.
    Is there anything better I should consider for this application?
    TIA
  2. Jerry Avins
    Jerry Avins Guest
    I've asked the staff at my local sewerage authority if that have a
    suggestion for you. I'll forward a response if it's pertinent.
    Jerry
  3. All the plants I've seen use ultrasonic. Hawk (www.hawklevel.com) make a
    range of ultrasonic level transmitters for waste-water applications and
    they're very easy to set up and pretty reliable.
    Another option is something from Drexelbrook. They have a wide range of
    contact-type magnetostrictive transmitters which can discriminate between
    the blanket and the water underneath and it might be worth talking to one of
    their reps..
    HTH,
    Cameron:)
