slow start up -15v regulator circuit
Discussion in 'Electronic Design' started by Paul Taylor, Dec 15, 2005.
  1. Paul Taylor
    Paul Taylor Guest
    Has anybody done a circuit for a slow start up negative voltage regulator? I
    am using a dual supply of +15 and -15v, I need the -15v to start up after a
    small delay the time is not critical! I know that you can do it with a +15v
    regulator any help on this is much appreciated.
  2. PeteS
    PeteS Guest
    The techniques are about the same. Without knowing the specific device
    and a general idea of circuit topology, it's hard to help.
    Cheers
    PeteS
  3. Fred Bloggs
    Fred Bloggs Guest
    There are basically two approaches: phase-in the regulator reference
    slowly or fool the feedback into thinking output is higher than it
    actually is for the phase-in period. Do you have any description of the
    regulator you're using or is that too much detail for you to handle?
  4. Rich Grise
    Rich Grise Guest
    Well, the pinout of a 7915 is different from a 7815, but other than that,
    just turn the caps and transistors upside-down, and it's the same circuit. :)
    Cheers!
    Rich
  5. LM337 and slug caps on the adj pin?
    martin
  6. ehsjr
    ehsjr Guest
    Here's a simple lock out circuit. It's a little different than
    what you requested, but a lock out not only provides the delay
    you want, it guarantees that Vin won't be killed by trying to
    start both regs at once if the + reg fails to start. A delayed
    start won't necessarily do that. It also interlocks the supplies
    so that -15 will drop out if +15 fails (which may or may not be
    desireable.)
    Ed
    +15 > ------+
    [R1]
    | +--- < Vin
    k| | o---
    [D1] [RY1] o--^
    +----+ +---> To - regulator input
    Gnd --------+
