James
I've got a 230v extractor fan, pretty standard and cheap, that's quite noisy
and too powerful for the room under the stairs that houses a fridgefreezer
and 4 computers that are on permanantly. Without the fan the computers get
too hot in summer.
I'd like to slow the fan down to a slower but constant extraction so the
room never builds up heat and have seen special fan controlers to do this
but they seem expensive. Is a light dimmer switch practically the same
thing? Could I use one without any undesirable complications?
The light in the small room comes on via a mains PIR when someone opens the
door. With the fan running slower and quieter, I'd like it to go to full
speed when someone enters. Could I wire the mains line from the light to the
fan directly, so when door closed it receives a small voltage from the
dimmer, and when door open it gets full mains from the light? Would the two
power sources overload the fan? Would the power coming from the light affect
the dimmer? Would it need a diode or am I just getting too complicated?
I'm not an electrician (as you've probably gathered) but I'm a good DIYer
and am seeking informed advice from people who know more about electrics
than me. TIA, James
too hot in summer.
than me. TIA, James
