Sir matty matt tmatty . . . . .
Back at my post one . . . . . at that time, I had
ZERO idea of
WHAT was wanting to be accomplished.
I just knew that the circuit I posted would positively get you introduced to the basic circuit familiarity to let you expand upon its basics.
After seeing the video, and what he had accomplished I now need to know what exactly you are wanting to accomplish, as you show us as having a large LCD plate instead of the two individual small eye size units that the other person was using..
Therefore, basically, I see zero need for the optical shutter, as replicating his effect of turning on and off of the LCD panel eyepieces only requires an application of voltage to darken the display and elimination of that applied voltage to make the display transparent again.
WITH one little caveat, that he discovered, which is the need of a bleeder resistor shunted across the display element to
SPEED up the deactivation of the blackened display, in going back to its transparent state.
When he utilized that backwards installed electrolytic, he created a bleeder resistor by virtue of the excess DC leakage thru the capacitor by that reverse polarity action.
Sooooo . . . . .we need a full fill in on your full application, in order to see if that left optical interrupter/ shutter
IS EVEN NEEDED.
Another question is if your display is being
CLEAR on its no power state or does there seem to be some degree of tinting.
ON HIS UNIT . . . . I know that his units incorporate 90 degree offset polarization filters that are alternatively switched on and off at a speed greater than the persistence of vision of the human eye . . . . .specifically,
MUCH FASTER . . . . due to the frame refresh rate of a LCD TV display.
ALERT !
(Crystal Ball prompt #1 is now glowing and coming in to me) . . . . . If this projects end result is being related to making a fast reaction shutter for welding “goggles “ the degree of opacity and spectral wave,length suppression, in no way approaches what is being needed for that capacity.
Here is the correction on the last schematic of yours, with its actual final state being depending upon what action you are trying to complete.
SCHEMATIC REPLOT :
The 470 gets the right current to the IR emitter with a 9V supply.
The 1k value should adequate to get adequate power needs thru the bottom loop
The Zener sets / limits the end supply voltage level going to the LCD panel
The 10K speeds up the drain of quiescent retentive voltage from the LCD panel . . . after its power off.
( Experimant and lower its resistance value incrementally, if decay time is being too slow.)
73’s de Edd
