My Slingcatcher was accidently plugged into a 10V power supply and now won't power on at all.
As it is now a discontinued product and out of warranty I can't get it repaired by Sling.
I've dismantled it and performed a visual inspection of the components to see if I could spot any obvious issues.
All of the components look fine except for what I believe is a diode just above the input power socket on the circuit board.
This component is labelled as D10 and appears burnt and has a bulge on the side of it.
It appears to have the numbers "315" and the letters "KE" on the top of it as well as a symbol resembing a "B"
Can anyone identify what the component is from the attached photo and if so does anyone know where I could buy a replacement?
I'm based in the UK
I'm based in the UK
