P
Phil Allison
** Just in case anyone missed it and needs a good laugh:
From SEB, 1-29- 2009
"Jon Slaughter"
" Thesis on DC Motors"
A motor has maximum torque at stall. Lowering the voltage reduces speed and
increases torque.
The reason has to do with the back emf. When the motor is stalled there is
no back-emf to resist current and hence large current can flow and hence a
large torque(since it is proportional to the current). As current flows a
back-emf counters it reducing the overall current.
If say, you lower speed by loading the motor so it can't turn then it will
overhead it. (this is easily demonstrated by jaming a fan and watching it
burn up)
But PWM is different!!! It doesn't load the motor to lower the speed but
reduces the current!! Hence at low speeds there is low average current but
high peak current since the rpms are low.
e.g., suppose the motor draws 1A at stall.
If we PWM at a duty cycle of d then d will control the speed(it will be
approximately proportional assuming no loading effect).
At, say, d of 1/100 which the motor turns slowly it will draw 1A but only
for 1/100 of the cycle. The average current is 10mA. This is definitely not
enough to get the motor to speed up.
What happens is you are "pulsing" the motor with high peak currents but low
average currents. An example is turning a bicycle wheel by your hand. To
keep it going fast you have to "pulse" and keep it up.. you can only get it
to go so fast though. Eventually it's inertia and your hand speed keep it
from going any faster.
If you grabed the wheel for only 1us and turned it with a huge force it
would be the same as some weak kid turning it continuously with a small
force. You might cause it to go fast quickly but only for that small time
frame.. for the rest of the time it is not getting any force(unlike with the
kid).
So even at stall speeds, while we are drawing a large current, because it is
using PWM the average current is low. (the peak current is still important
for practical matters though)
You have to realize that the "impedence" of the motor depends inversely on
the angular velocity. It is independent of the duty cycle. The PWM basically
prevents enough average current to cause it to spin up to speed(again, even
though high peak currents occur).
About the only thing you can say is that at low speeds you have high peak
currents and vice versa. PWM is simply controlling the average current.
"Jon Slaughter"
increases torque.
burn up)
kid).
