Siren question - 12V 1A enough?
Discussion in 'Security Alarms' started by DeanB, Mar 18, 2009.
  1. DeanB
    DeanB Guest
    Hi all,
    I have a linear corp alarm and want to buy an outdoor siren alarm -
    the specs on the alarm are 12V and 1A maximum, which equates to 12W (I
    think).
    All the sirens online appear to be 20, 30 or 40W and people mention
    quite often they are not loud enough. Can I run a more powerful siren
    with a relay or something, or what siren would be best?
    Thanks!
  2. mleuck
    mleuck Guest
    Which Linear system?
  3. alarman
    alarman Guest
    Those wattages refer to the speaker wattage. A 30 watt siren will use almost
    2 amps at 12.5 VDC.
  4. DeanB
    DeanB Guest
    DVS2400
  5. Crash Gordon
    Crash Gordon Guest
    That thing would have a heart attack if you connected a big siren to it.
    **Crash Gordon**
  6. Jim Rojas
    Jim Rojas Guest
    Use a separate power supply and a relay to power the siren.
    Jim Rojas
  7. DeanB
    DeanB Guest
    Yes, that seems the way to go. I'm going to try the Amseco SSX-51
    which pulls only just over 1/2 amp, and if its no good then I will
    hook up a relay. It has good reviews so we'll see.
  8. Crash Gordon
    Crash Gordon Guest
    You can use a spkr or a siren.
    The siren output is rated at 1 amp @ 12v
    It also has wet & dry relay outputs.
    **Crash Gordon**
  9. DeanB
    DeanB Guest
    I'm going to use the speaker terminals for the voice output and
    beeping (and I guess also the alarm sound) so that I can hear it more
    easily from the entrance. The main unit is out of sight. If I am
    right, I think it has a siren output as well.
  10. Crash Gordon
    Crash Gordon Guest
    has both.
    I'd use the speaker...less draw on the puny battery.
    **Crash Gordon**
