W
William Beaty
The Sipex DAC9377-16-4 has a strange aging problem: resistors in the ladderwill drift in value until the analog output is not only non-linear, but entirely crazy.
DAC 9377 is common in hospital NMR, military simulators, and older custom research instruments. (If it ran any proportional hydraulics in manned simulators, they'd be in for an increasingly rough ride over the years.) The old chips are expensive if you can find them at all, and of course may suffer the same aging problem.
So, build yourself an adapter-board to match Texas Inst DAC712 pinout. Seelink below. Needs one signal inverted, pullup/gnd of mode pins, and zero/gain trimmers on board. See:
http://staff.washington.edu/wbeaty/chem_sipex9377.html
