single pulse
Discussion in 'General Electronics Discussion' started by theredstealth, Sep 15, 2011.
  1. theredstealth
    theredstealth
    3
    Sep 15, 2011
    I'm building a circuit and I need it to send out a quick pulse when powered up to set a 4029counter to a certain value every time. I can not come up with anything.
  2. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    You need a "power-on reset". Capacitor and resistor in series across power supply. Capacitor to Vdd and resistor to Vee. Junction of resistor and capacitor to CD4029's Preset-Enable...pin 1. How fast is the clock input? Try a 10KΩ and a 0.1µF. Depending on the CD4029 counted circuit, you might want to add a 1KΩ resistor across the Vdd to Vee. This is to assure discharge of the added capacitor when power is removed.
    Ken
  3. theredstealth
    theredstealth
    3
    Sep 15, 2011
    Thank you for the info
    Clock will be controlled by switches. Solenoids will be controlled by counter output as well 7-segment display.
    So if I understand you correct, Vdd is power and Vee is common. which means;
    Power------>Capacitor------->P/E & resistor----------->common
  4. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    Yes, that's what I had in mind.
    Ken
  5. theredstealth
    theredstealth
    3
    Sep 15, 2011
    thanks for the help, we just had an example of this in class today, if I had asked this question I wouldnt have realized the purpose of the circuit and it would have been just another diagram. now I know how it actually works.
