G
gazz
i'm making a home games room, currently have a few old fruit machines, a
pinball machine, jukebox, japanese pachislo machine and so on,
i've converted the coin mechs on them all to take the pachislo tokens,
because i have lots of them, and it's a lot easier than having to keep each
machine stocked with real money for wins.
i've also made a token dispenser, simble wooden cabinet, a coin controls
universal hopper holds the tokens, which it spits out 1 for every pulse of
12 volts it gets,
a coin validator takes real money (to save up for the electric bills
The coin validator takes care of checking the coin is real and it's value,
it then puts out a + 12 volt pulse on one of 5 pins (i.e. so 5p gives a
pulse on say pin 1, 20p gives a pulse on pin 3, 1 pound gives a pulse on pin
5 and so on) each coin registered gives out 1 single pulse.
There are commercial credit boards i can buy for about £30 to convert the
single pulse on different pins, to output multiple pulses to drive the coin
hopper, but my budget dosent stretch to the price of the commercial board,
not to mention the company that sells it are a pain to order from.
so i thought i'd build my own, should be simple?
i was thinking of maybe 555 timers, but was wondering if anyone has a better
idea, and can give me a circuit diagram to do what i want,
i can solder, draw pcb's in eagle, etch them, buy components,
i just fall down designing the circuits.
what i need is... 5 input pins, which each can take a 12 volt pulse of about
250 milliseconds duration,
depending on which input pin is pulsed, it outputs a set number of 12 volt
pulses on a single ouput pin,
these need to be greater than 5 milliseconds in duration and appart, the
hopper has circuitry in it to store the pulses it recieves, so it can
recieve 100 pulses in what ever time it takes to send them with 5ms delays
and durations, and will pay out 100 tokens in what ever time it takes to do
that.
i need pin 1's input to output 5 pulses, pin 2's input to output 10 pulses,
pin 3's input to output 20 pulses, pin 4's input to output 50 pulses, and
pin 5's input to output 100 pulses.
If possible i'd like it to be able to take multiple input pulses and count
the correct output pulses.. i.e. put in 5 x 20p coins, which will pulse pin
three 5 times, and it outputs 100 pulses,
or it could have a seperate output that goes to 0 volts whilst it is
outputting the pulses... this would be connected to the coin lockout pins on
the coin validator, preventing any new coins being registered and rejecting
them untill the circuit is ready to acceps another coin/pulse output.
Can anyone come up with a circuit diagram to do this?
12 volts it gets,
that.
