Single phase motor with relay and 2 capacitors
Discussion in 'Electrical Engineering' started by Tor Tveitane, Apr 5, 2005.
  1. Tor Tveitane
    Tor Tveitane Guest
    Someone disassembled a single phase electric air compressor motor with start
    relay and two capacitors.
    I'm unsure how to connect up the two capacitors (5uF and 30uF) and the
    starter relay to the motor windings. This must be fairly standard stuf, so
    does anyone of you know where to find a simple schematic of a 1 phase
    electrical motor with starter relay and two capacitors?
  2. BigWallop
    BigWallop Guest
    You should find this type of info' on this website
    http://www.electricmotors.machinedesign.com/
    Hope it helps.
