Single IC linear adj. pulse generator
Discussion in 'Electronic Design' started by [email protected], Sep 3, 2003.
  1. Guest
    I need a single IC pulse generator with a range of 1-20 Hz that has a
    _linear_ frequency adjustment via a potentiometer. Duty cycle
    adjustment via trimpot would be an added advantage.
    Can anyone advise where I can find a schematic for this?
    As far as I am aware making an LM 7555 linear adjust entails
    additional active components. For design reasons, I would prefer not
    to do this, or use a dedicated function generator IC, ie. XR 2206,
    etc.
    Thanks for your response
    Peter Nielsen
  2. Jim Thompson
    Jim Thompson Guest
    And *why* is that? Homework problem ?:)
    ...Jim Thompson
  3. Ban
    Ban Guest
    Here is a nice and very linear variable duty cycle square wave oscillator,
    which will work from less than 0.01Hz to 20Hz, but with proper scaling of
    charging current and -capacitor and high speed comparator you can easily
    reach 20MHz.
    If you want a very linear adjustment, you will have to use a voltage
    controlled current source at the frequency input and a buffer at the duty
    cycle input.
    If you buffer the capacitor voltage you have a *very* linear triangle wave,
    suitable for reference use in a delta A/D.
    ciao Ban
  4. Ban
    Ban Guest
    see schematic below, forgot to paste it
    +-----------------+-------+----------------------o
    | .-. .-. 10V
    | 1k0| | 1k0| |
    | | | rail to rail comparator/opamp
    | frequency | | | |\ |
    10k | |<-------+ | | V V | | >--+--#
    | | .-. | +-+ | | +-|+/ | out
    | 100k| | | V V 10u| + | ___ |
    +---+ '-' | +-+ ### +-|___|-+
    | | | | 1N4148| --- | 10k
    +-| | | | | GND | ___
    |> \| | |/ |/ | +-|___|-VCC
    | |-+---------| | | 3k3
    GND <| |> |> | .-. duty cycle
    .-. .-. .-. | |100k
    1k0| | 1k0| | 1k0| | '-'
    | | | | | | | ___
    '-' '-' '-' +-|___|-GND
    | | | 3k3
    GND GND GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
  5. Fred Bloggs
    Fred Bloggs Guest
    A very simple way is shown here- you can use a single supply 15V and
    derive the 5V by zener or some other regulation, or you can use a single
    5V and use a 2nd 555 and diode voltage tripler to derive ~15V:
    View in a fixed-width font such as Courier.
    freq adj
    15V
    | 10k 10k 10k
    c | ---
    \| | gnd
    npn|--------------------+
    e
    | duty adj
    1.5k 10k 10k 10k
    5V / | /|\ |
    o e | | ---
    | |/ | | Vth gnd
    +-----|pnp | |
    | |\ | | 1M
    | c | +---/\/\------+
    | | | | | comparator
    | | +--vcc---+ | | |
    | I | | +------(+)\ |
    | | | 555 | | >--+----> Pulse
    | V | | +------(-)/
    +----+-----+-thresh | | | 3xI
    | | +-trig | | | Frequency= ------
    | === +-dis | | | CtxVcc
    | CT | | | |
    | 47u +-- gnd -+ | |
    | | | | | Vth
    | +------------+-------------------+ Duty= --- - 1
    | | | 1.6
    | gnd
    | / / / -3.4-
    +-> -+------+------+------+-----Vth-
    -1.6-
    - - - - -5-
    | | | | | | | | Pulse
    -+ +----+ +----+ +----+ +----0-
