Single Frequency Network and Multiple Frequency Network
Discussion in 'Electronic Design' started by MRW, Nov 29, 2007.
  1. MRW
    MRW Guest
    Good day! I am very confused with Single Frequency Networks and
    Multiple Frequency Networks when used in digital TV broadcasting.
    I grasp the concept of MFN architecture okay. I can see that different
    TV stations will require a different transmitter at a different
    frequency when transmitting the same program in order to increase
    coverage.
    With this, I can safely assume that a TV station using a SFN setup
    will still require multiple transmitters for the same program, but
    this time only use one frequency.
    But I do not have the answer to whether multiple TV stations with
    different programs is possible in 1 SFN setup. I keep reading about an
    SFN architecture being spectrum efficient. What exactly does this
    mean? Is this indicating that different TV stations can transmit their
    programs just using 1 SFN setup?
  2. JosephKK
    JosephKK Guest
    MRW posted to sci.electronics.design:
    Include physical distance in the SFN concept. Also called "area of
    coverage".
