N
Nico Coesel
Some food fo thought:
I'm working on a new design in which I need to bring 64 LVDS (250Mbps
each/ 125MHz fmax) lines into a Spartan3 FPGA. The distance between
the source and the FPGA is less than 2" / 5cm. Ofcourse there is a
solid ground plane underneath the signals (the board will have at
least 4 layers).
I'm wondering if I can save a lot of pins if I feed the LVDS signals
single ended into the FPGA (terminate the pair close to the FPGA and
leave one end dangling). I could bias the Vref pins on the FPGA to the
centre point of the LVDS signal. If I set the input pin type to GTL it
should work on paper. The LVDS signal has enough swing to exceed the
minimum signal amplitude.
Anyone ever tried this?
least 4 layers).
