Single command IR transmitter?
Discussion in 'Electronic Design' started by Ken Taylor, Dec 7, 2005.
  1. Ken Taylor
    Ken Taylor Guest
    Hi. Try:
    http://www.mindspring.com/~redrocker1/RCR_Report/RCR_Report.htm
    and
    http://www.epanorama.net/links/irremote.html
    or even:
    http://jap.hu/electronic/codec.html
    (etc)
    Use the keywords 'remote control','pic' and 'schematic' for searching.
    Cheers.
    Ken
  2. George
    George Guest
    I've considered building my father a dedicated remote switch which
    could mimic the "mute" code for his TV remote. The TV is a Mitsubishi
    VS-5017S (one of those older, giant ones).
    I've read through a bunch of the remote related posts here and have
    gone through some web info, which was mostly for repeat/extenders and
    some relay trigger circuits, etc.
    For the command code itself, I've seen some sites on how to obtain a
    remote's signals, and they looked fairly straightforward, but I'd
    obviously rather find the info online to save some time, if it's
    already been recorded by someone else.
    Assuming I can find out what to send for "mute", does this transmitter
    endeavor sound overly difficult or impossible for someone on the
    novice level? If not, could anyone possibly point me to a decent DIY
    example or some info somewhere on how to go about it?
    It would probably only be worthwhile if the device were relatively
    compact and could be supplied by a small internal battery. I've got
    some PCB layout/etching capability here, and If there might be a
    microprocessor involved, I've done some simple PIC programming, which
    required a few tedious clock cycle/timing adjustments for proper
    serial rate output, so that would probably be the better "brain of
    choice" for me. Don't know how complicated a circuit or application I
    would be able to handle though.
    Much Thanks!
    (and please reply within the group)
    George
  3. Guest
    I've done a fair bit with IR using PICs. I've used a 12F683 to drive a
    transistor which in turn turns on and off an IR LED.
    The 12F683 has a HPWM module, this means you can turn on and off the
    modulated signal very easily. All you need to do is program a few
    registers with values that result in the correct modulation and duty
    cycle for the signal you're sending. This PIC also has an internal
    clock so there is no need to worry about external crystals etc.
    The software then needs to turn the HPWM output on and off with the
    data signal its trying to send, and you have a modulated signal going
    straight to the IR circuit.
    The HPWM output pin needs to be connected to the base of the
    transistor. The IR LED, resistor and transistor (collector/emitter)
    connected in series to complete the signal circuit. The reason for
    driving it from a transistor is that the IRLEDs draw more than the 25mA
    that PICs allow. I've used a BC549, but there are probably better
    parts around as the BC549 has a maximum of 100mA while the TSAL6400 (IR
    LED) can easily draw 100mA. The resistor values needs to be calculated
    based on the supply voltage and the rating of the IR LED you use.
    I've run this type of circuit off a tiny battery for many many presses
    and it works fine. My design caused the power circuit to complete when
    a button was pressed so there was no need for standby/sleep modes on
    the PIC. It took the form of a 3 button car remote style device, each
    sent a different signal series. Combined with a TSOP4837 (I think)
    receiver for learning new signals this proved a handy device for a lot
    of people.
    There are loads of articles on the net around IR signals, RC5 codes
    etc, so you need to find out what signal type this TV uses. Also
    remember that a lot signals are toggles, the only exception being power
    which often has an on, off and toggle signal.. allowing more
    flexibility in the way its used.
    Components:
    PIC 12F683 £1.30
    TSAL6400 £0.25
    BC549 £0.10
  4. Yes its possible but complicated for a novice. The protocol links are
    needed but I didn't see the actual transmit data for the individual
    functions I.E they tell you HOW to send the bits but not WHICH bits to
    send. I compiled the list for Samsung last year using an IR module into
    a Tek TDS-3000 scope and can now receive and trasnsmit any function (it
    is used for transcoding the monitor and set top box commands). Its
    definitely easier to transmit than to receive. BUT, since you only want
    mute, wouldn't it be easier to re-package a universal remote that
    already works? Building your own can be a good learning experience but
    will use a chunk of time.
    Good luck
    GG
  5. Guest
    The PIC that I used I selected because it has the builtin hardware PWM.
    This allows you to generate many different output frequencies no
    matter what speed you clock it at. It also has a reliable built-in
    clock source so no need for external crystals or resonators.
    The circuit is tiny (when on a PCB). For the project I used the
    following case available from http://rswww.com - search for 451-0674 or
    just the word Keyfob and you'll find it!
    I didn't have any problems with power-up delays because the PIC has its
    own power-on delay to ensure its stable so that wasn't a worry.
    Powerdown was instant, just as on a remote. My circuit went something
    like this:
    | PIC 12F683 |
    ___ | ___ IR LED RED LED
    +v ----o o----+---/ \----->|------->|----+
    Sorry - first try at ASCII circuit diagrams! The red LED was used as a
    confidence thing, and depending on the LEDs used depends on if you need
    a resistor or not. The whole circuit works off a 3v cell (lithium).
    The cases I've mentioned take a 12v cell unfortunately, so in that case
    I used a very low powered 7805 to take it down to 5v which works well.
    I did try and find a 3 to 5v cell in the same size, but couldn't find
    one.
    I typically clock my projects at 4Mhz unless I have a reason to need
    the other frequencies. You use various registers to calculate out the
    PWM frequency you need for the clock speed you're running at. So for
    example, so you need a 38Khz modulation you'd take 4Mhz = 4000000,
    divide by 4 = 1000000. Divide this number by the frequency you need,
    38000, this gives you 26 (when rounded). Load this in to the PR1
    register (I think). Obviously because of the rounding you'll be
    generating a slight offset, you'll generate 38461Hz. Thats close
    enough not to make any noticable difference to the range or sensitivty.
    If you play around with the pre/post scalers on the time you might be
    able to get something more accurate.
    You'll also need to configure a duty cycle, I think most remotes are
    about 20%. You need to work out the number of bits available for your
    clock and duty cycle. Its in the datasheet... so work it out and from
    there you look at the: I've got 6bit resolution (for example), the
    lower two bits sit in one of the PWM register, the remaining upper 4
    bits sit in their own register. Be sure to clear the upper bits of the
    that register when you configure it, otherwise it can do odd things.
    If we're looking at a 20% duty cycle at 6 bits you need to store the
    decimal value 12. Zeros in the lower two bits, and the number 3 in the
    upper byte. I hope all that makes sense, but unless I know the exact
    frequencies I can't give you precise values.
    Then only timing you need to work out is the one for the real signal,
    which can be done in most high-level languages rather than worry about
    asm. If you needed to do the whole modulation in software you'd need
    to asm only otherwise the high level language will screw up your
    timing.
    Comm port serials i'd be careful of.... they don't typically use basic
    IR they're normally Irda or something else....
    If you want to work out what the IR signal is, the way I did it was to
    buy a Vishay TSOPxxxx part. That has a logic output that you can
    connect on to a PIC. Then all I did was have a timer routine, it
    starts a timer, waits for a state-change on the pin, stores the timer
    value at that point, clears it and restarts the timer, then sends the
    result via the serial port (in ASCII). Run a terminal program at the
    other end, this will dump a load of numbers out giving you the timings
    for the signal received. Its how I reverse engineered a proprietry
    system that didn't use standard codes. Obviously you have to repeat
    the codes a few times to get reliable results but it should give you a
    good idea of what to generate. As a test I just too the timer figures,
    put them in a table, then altered the code to turn on and off the IR
    output in line with the table and the timer - resulting in the signal I
    needed.
    I hope that makes sense! For the record I use Proton+ to write PIC
    apps in... its a bit faster than using asm (which I have used for
    things like the 68HC705C8 - old process now!)
    Mike
  6. Ian Stirling
    Ian Stirling Guest
    If absolute size is not utterly critical - what's wrong with a
    'one for all' or learning remote?
