flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
Looking for a single channel inverter that will take as a square wave input, a 0V level which rises to 3.3V for one second and then drops back to 0V, and convert it to a 3.3V square wave output which falls from an initial constant 3.3V, to 0V for one second before rising back to 3.3V
The input comes from the centre of a 4k7/10k voltage divider across the wider circuit's 5.0V supply rail, switched on the positive side of the resistors by an NPN transistor.
If necessary I could power the inverter in some manner from the wider circuit's 5.0V supply rail.
It should be as simple & cheap as possible and consume as little power as possible, whether composed of discrete components, or an IC. I'd like to avoid using a large chip with loads of redundant inputs, just seems wasteful?
This is to condition a control signal feeding into the 'Addkey 1' input of a 'DFPlayer Mini' mp3 player module.
Could a 741 op-amp be a good solution? My signal's not actually electrically inverting though is it.. it's only a logic state inversion.. head's about to burst :-(
