N
Napalm Llama
Hi. I've been tinkering with the odd electronics project for a few
years now, but I'm stumped on this one. I've constructed this circuit:
http://www.yellowmackerel.co.uk/circuit.gif
(Originally from here: http://www.4qdtec.com/singen.html , but the
server seems to be down.)
....except I'm using an NE5534AP op-amp instead of the 6-transitor
circuit (as the accompanying text said I could).
But it isn't working. All I get is a low tone that sounds suspiciously
like 50Hz. I've checked the power supply circuit with my multimeter
and the output seems to be perfect, but I can't check how much ripple
there is because I don't have an oscilloscope.
The dual-ganged potentiometer seems to alter the volume instead of the
tone, and the rotary switch doesn't really do much at all. The op-amp
itself just gets worryingly hot.
I've just discovered that if I only connect 0v to the IC and put my
thumb across the "lower" pot in the circuit, moving it does alter the
tone a little.
I don't know if this is enough to go on, but please help in any way you
can - I've spent a fair bit of money on this project and I don't know
why it isn't working...
tone a little.
