I would like to control a number of high voltage led arrays at various speeds and duty cycles.
Each led array is controlled/switched (on and off) by a logic level mosfet. All is tested and working fine at that end, thanks to all the help I received in this forum, he he.
All needed is the controlling side, and I thought of using a Arduino. Tested the control of one object with PWM output on the arduino. This works fine to pulsate from dimm to full brightness on one pin.
What I would like to achieve is controlling multiple arrays (22), pulsating at different duty cycles at the same time with various delays in between.
Could anyone help me to achieve this, and what would be the best solution.
