S
Scott Ronald
Hi
To continue this discussion about simulation of incremental difference
equations, I was wondering how you could add a power source to the code
that John Larkin came up with.
I have been experimenting with this and I found that merely adding the
voltage like
//FOR T = 0 TO 1 STEP DT
// IL = IL + (Vin-Vout) * DT / L
// IR = Vout / R
// IC = IL - IR
// Vout = Vout + IC * DT / C +myVoltage
//NEXT
causes problems because the voltage accumulates in the Vout variable and
the voltage quickly goes very large. Do I need to subtract the previous
voltage before I add the new voltage like:
// IR = Vout / R
// IC = IL - IR
// Vout = Vout + IC * DT / C +myVoltage-lastvoltage
// lastvoltage = myVoltage
//NEXT
Would this be remotely accurate?
Here is the circuit I am looking at:
[Input]--[coil]---|-------|----[output]--|
| [cap] [resistor] [voltage]
[ground]
Scott
simulate a really simple RLC circuit (2 network). I know that I can use
one of the freely available programs to do this, but I want to be able
change the input voltage arbitrarily with my own code using feedback
from the output of my circuit.
voltage like
// IR = Vout / R
// IC = IL - IR
//NEXT
// IR = Vout / R
// IC = IL - IR
//NEXT
[ground]
Scott
HiIt seems like spice variants cannot do this, and I do not know how to create the differential equations to write my own code.
What r-l-c topology did you have in mind? It's not hard to program the
incremental difference equations.
But Spice program can do most anything.
John
I need to do something like this:
[Input]-|-[coil]-----|-----[output]
| [cap] |
[ground]
I hope this is readable.
No resistor?
OK, assume a time step DT.
Oops, make that first line
Vout = Vout + IL * DT / C
NEXT
Wow that is great, is there a textbook somewhere that covers this technique?
How would it change if I add a resistor?
[Input]-|-[coil]-----|-------|----[output]
| [cap] [resistor]
[ground]
