A
Abstract Dissonance
I was wondering how I can simulate microcontrollers. I am trying to make a
simple "switching" circuit that basically lets users push buttons to call up
presets that will switch between different "devices" and I figured that I
would use a pic to do it. Unfortunately I have virtually no experience with
any electronic stuff and I've just been playing around with EW Design Suite
with flip flops and stuff to get an idea about what I need to do. From a
little research I figure that I can do all the controlling with a pic with
enough I/O lines and just do the switching and selecting in the software...
the problem is I can't figure out how to put code in Design Stuite when I
put down a MCU. I'm not sure if DS supports this or not but I have found
several other pieces of software that either just simulate the chip itself
and has a IDE for the code(but doesn't seem to simulate the electrical
circuit aspect) or they just do the electrical circuits but not the code. I
looked on EW's site and they had something called MultiMCU that interfaces
with DS and does seem to do what I want but I'm not completely sure... and
I'm definately looking for something that is free so I can play around with
it and use it to learn.
Any ideas? Or am I just going to have to purchase some hardware and a
programmer and do it that way? I'd rather use software simulation as I'm
much more comfortable because I can't really screw anything up.
Anyways, I'll give my idea since its pretty simple and might shed some light
on what I actually need(I know I probably don't need to simulate anything to
do it since its pretty simple but I'd like to be able to play around without
any fear of screwing up the chip by accident).
I'll have N buttons that will select "presets". I'll need the ability to
store the presents in memory.
B1 -- |-----| --- DEVICE line 1
.... | MCU | ...
BN -- |-----| --- DEVICE line M
So basicaly I have a Device which has M lines and I want to just select
combinations of those lines (so I have M! possible combinations to choose
from but only N buttons(4 probably) will be selectable(or maybe I'll use
some bank method to get a few more)).
So, say for example, B3 might have been configured by the user to select
some preset that turns "on" lines 3, 6, and 8 and B4 might turn on lines 1,
2, and 3. I figure its pretty easy to do in the software but since its
actually a little more complex than that I'd like to simulate the other
parts of the circuit along with the MCU. In actuality I need to debounce the
switches(They are just momentary switches) and the Device lines are actually
analog lines so the MCU will control switches that switch on certain analog
line combinations.
Also, I was wondering how much does it cost to fabricate this stuff
"professionally"? Right now basicaly what I have done is to use dip
switches to select different combinations of the DEVICE lines above... my
goal is to make it much easier by just using a few switches(maybe I can just
get away with one or two too and just use a button to cycle through the
presets instead... maybe not)). For my application I am limited in size(the
smaller the better) and the analog signals that it will control cannot be in
any significant way be degraded. I'd like to put this in a small package
and potentially sale it if I can find someone to buy it(not sure if theres a
market for it but I'm sure a few people will buy it if its done right)...
although its mainly just a stepping stone into learning more about
electronics as I've always been wanting to get into it(and I've taken a few
courses in EE).
Thanks for any help,
AD
.... | MCU | ...
line combinations.
courses in EE).
AD
