Hi guys,
Afraid I'm a bit of an electronics newbie, so be prepared for some foolishness in my question
Hoping for a clever solution to a seemingly insurmountable problem...
I'm building a guitar at the moment and as I'm sure you know, the tone pot usually uses a fixed value capacitor to act as a filter.
I would really like to be able to use a variable capacitor so that I can adjust the threshold of that filter.
Obviously variable capacitors exist, but as they are all in the pF range (at least the ones that would fit into a guitar), I would like to simulate the effect of one.
Can this be done in any sensible way?
Obviously I could use several capacitors with different values and some sort of switching arrangement, but was hoping for something a bit neater.
Perhaps something involving a couple of different capacitors with a potentiometer to vary the amount of signal going to each?
If you haven't pulled your hair out at the silliness of this question, congratulations!
Thanks very much,
JonBass
Thanks very much,
JonBass
