M
Michael Noone
Hi - I need to take a signal coming from a 3K potentiometer that ranges
from 0.44-1.77V and double it (so I'd have an output of 0.88-3.54V). That
output will be then fed into an ADC. I have available on the board a very
stable 5V supply, and a less clean 6V supply. The ADC is 10b with a 4.096
reference voltage, and I'd like to keep this circuit accurate enough to a
single bit. My first thought is a non inverting amplifier - but that's one
chip and 4 resistors per circuit, and since I need three of these on the
same board, 1 chip and 12 resistors total. That's quite a bit... Is there
any better way? I've seen some dedicated chips designed for current
monitoring that would amplify a signal by a much higher gain - 50 or 100
without any external components at all, is there anything like this that
would work for me?
Thanks for your help!
-MJ Noone
would work for me?
-MJ Noone
