simple usart programming problem
Discussion in 'Electronics Homework Help' started by kuanny, Jan 30, 2014.
  1. kuanny
    kuanny
    3
    Jan 30, 2014
    //Laboratory No:1
    //File name:Lab1.c
    //Student Name:Goh Chee Tatt
    #define XTAL_FREQ 4MHZ
    #include <htc.h>
    #include "delay.h"
    #include "lcd.h"
    #include "usart.h"
    #include <stdio.h>
    #include <stdlib.h>
    #define _XTAL_FREQ 4000000
    /*Lab1.c - Turn ON PORT B 0 LED*/
    __CONFIG(0x3f31);
    unsigned long int i;
    delay1s()
    for(i=0;i<30000;i++)
    NOP(); //no operation is carried out
    main()
    TRISA = 0;
    TRISB = 0b00001000;
    TRISC = TRISD = 0;
    PORTA = PORTB = PORTC = PORTD = 0;
    //ADC OFF
    ADCON0 = 0;
    ADCON1 = 0b110;
    //control bytes for usart( Bluetooth )
    SPBRG = 25; //4MHz
    TXSTA = 0x24;
    RCSTA = 0x90;
    //USART interrupt
    RCIE = 1;
    GIE = 1;
    PEIE = 1;
    while(1)
    PORTB=0x01; //set pin0 of portb as high
    delay1s();
    lcd_goto(1,1);
    PORTB=0x00; //set pin0 of portb as high
    TXREG = 'A';
    void interrupt usart(void) {
    if ( RCIE && RCIF )
    switch( RCREG )
    case 'A' :
    lcd_puts("hello");
    break;
    i am trying to send data from my tx pin to my rx pin, i cant see any problem with this program however it fails to run.
    this is my error message
    Clean: Deleting intermediary and output files.
    Clean Warning: Can't delete file "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project.p1" from disk. (32)
    Clean: Deleted file "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\usart.p1".
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.cof" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.hex" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.sym" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.map" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.hxl" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\startup.lst" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\startup.rlf" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\doprnt.p1" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\doprnt.pre" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.obj" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.lst" doesn't exist.
    Clean Warning: File "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.rlf" doesn't exist.
    Clean Warning: Can't delete file "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.sdb" from disk. (32)
    Clean: Deleted file "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1.mcs".
    Clean: Done.
    Build C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project1 for device 16F877A
    Using driver C:\Program Files (x86)\HI-TECH Software\PICC\9.70\bin\picc.exe
    Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.70\bin\picc.exe" --pass1 "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\mini project.c" -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
    Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.70\bin\picc.exe" --pass1 "C:\Users\user\Desktop\engineering degree\Eng 2018M\lab1\usart.c" -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
    Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.70\bin\picc.exe" "-omini project1.cof" "-mmini project1.map" --summary=default --output=default "mini project.p1" usart.p1 --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
    (1273) Omniscient Code Generation not available in Lite mode (warning)
    HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.70
    Copyright (C) 2009 Microchip Technology Inc.
    ********** Build failed! **********
  2. Somethingrandom
    Somethingrandom
    22
    Jan 20, 2014
    The compiler isn't outputting a reason for the failure. Is this a feature you have somehow disabled? I would also suggest deleting all intermediate files and doing a full rebuild.
