D
Danny Sauer
Ok, so I know a little about electronic devices. However, I don't
have the parts/spec books memorized like lots of people who do this
stuff all the time.
I'm making a device to make my tail lights flash in entertaining
patterns. It's overkill, but I'm using a PIC microcontroller (a
16f676) to handle the flashing patterns. I've got the device working
just fine with LEDs, but actual 1157 taillight bulbs pull way more
current, which I'm pretty sure will be too darned much for this little
micro to handle. My plan is to replace the LEDs with a transistor to
control each bulb individually. The bright side of an 1157 is usually
around 25-30 watts, so at 12 volts that gives me a worst case of about
2.5 amps. How about allowing for 3 amps at 14.4 volts - 43 watts.
What would be a good transistor to use for this? I can switch either
the positive or negative side, it doesn't really make any difference,
though switching the positive side would likely be a bit more
convenient (more wire to work with).
Can someone recommend a supplier and a part number or something where
I can get stuff in relatively small quantities? I only need about 8
per device, and I'm only building one or two devices for the time
being. If I could get something at the local Radio Shack (there are
no electronics suppliers nearby other than that place), that'd
probably be alright, too.
Thanks a lot!
--Danny
stuff all the time.
Thanks a lot!
--Danny
