Simple solar powered lights with a battery
nabberuk
Jul 25, 2012
9
Jul 25, 2012
9
hi,
I have some fairy lights the are powered by a 3v battery, also I have a solar cell that's 6v and 4.5w/520mA. I would like to charge a battery pack (haven't got one yet, was thinking of a couple of a cells in series and parallel) with the solar and then power the lights at dusk - I believe I can use the solar to detect dusk.
Other than that, I'm pretty stuck so if anyone could point me in the right direction
donkey
Feb 26, 2011
1,301
Feb 26, 2011
1,301
ok so how skilled are you?
what size battery you looking at? amp hours matter
what type of charger yo using? lipo and standard batteries (AA< AAA etc) use a special charging circuit from memory. SLA batteries take what you give them.
what are you going to do with the 3volt battery?
nabberuk
Jul 25, 2012
9
Jul 25, 2012
9
Not very skilled at all when it comes to electronics!!
Looking at standard AA batteries, unsure on the amp hours but would need a 4-5 hour run time. During the day the solar cell would charge the batteries.
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
White LEDs have a forward voltage of at least 3V, so you'd need 3 or 4 AA cells in series to drive them directly. Alternatively a DC-to-DC converter could step up the voltage of a single cell (as is done in most garden lights).
Your solar cell rating is probably an optimistic one for full sun at the equator :), so don't expect 6V throughout the day.
nabberuk
Jul 25, 2012
9
Jul 25, 2012
9
Yeah I guessed that I wouldnt get the full 6 volts, I've been testing it in our gloomy weather and I've been getting around 4.5 volts.
On the old solar that came with the lights, it contained a single aa cell so it was stepping up the voltage, it had other circuitry in to switch between flashing etc that I'm not fussed with.
So I though I would build a separate one. Just not sure on how!
