Simple radio transmitter/receiver
Discussion in 'Electronic Design' started by Norleif Slettebø, Sep 8, 2005.
  1. I'm going to make a remote control for some equipment, and was thinking
    about using a small radio transmitter, to avoid some of the issues related
    to IR.
    The basic idea is to just make a simple oscilator that operates in the RF
    band, and use the built-in UART in the remote microchip to turn the
    transmitter on and off, in a sort of binary AM style.
    On the receiving end, I was thinking about using a receiver tuned to the
    frequency of the transmitter.
    When the transmitter is ON (Binary 1 from the UART), the receiver detects
    the signal, and turns the output to a binary 1.
    When the transmitter is not transmitting (Binary 0 from the UART) the
    receiver doesn't detect anything (beside background noise) and the receiver
    output drops to a binary 0.
    For starters.. Is this doable?
    If it is, where should I go to try to find some simple scematics for the
    transmitter and receiver?
    I would imagine a simple RF oscilator would be enough for the transmitter.
    Maybe use RC model crystals to maintain a stable frequency.
    Any suggestions?
  2. its all to do with range and data rate
    try this, from their newsletter to me
    http://www.lprs.co.uk/calculator/in...content=easyRadio&utm_campaign=RFIC+or+module
    martin
  3. Andy
    Andy Guest
    Andy writes:
    I would suggest a copy of The Radio Amateur's Handbook.
    It has hundreds of circuits that can be copied to implement your
    requirements, and also serves as a very useful source for a theoretical
    treatment, on a level which you might find helpful.
    It also has sections on data transmission from the simple OOK
    technique which you propose, to more sophisticated circuits using
    other techniques, such as FSK, which offer some advantages.
    This book is published every year, with changes and updates, by
    the American Radio Relay League, in other words, "ham" operators.
    You might enjoy this as a hobby. I started in high school 50 years ago
    and have been building stuff ever since.....
    Good Luck,
    Andy W4OAH
  4. Wes Stewart
    Wes Stewart Guest
