simple PC interface to ADC/DAC
Discussion in 'Electronic Design' started by Adam Seychell, Apr 1, 2004.
  1. For a instrumentation circuit which I am designing I need to somehow
    interface a 16 bit DAC and a 16 bit ADC to the PC and send data at a
    continuous sample rate of 2 KHz. My idea so far is to use a USB->8bit
    parallel IC (FTDI's FT245BM), and bit bang the serial data to the DAC
    (TI's DAC8501) and ADC (TI's ADS320) IC's.
    The software would write and read blocks of data to the 8 bit port of
    the FT245BM at a fixed sample rate. The I/O lines will connect
    directly to the serial I/O pins of the DAC & ADC. How will this idea
    work ?
    One foreseeable problem could be difficulty in writing the software to
    translate the DAC and ADC samples into serial information and then
    put/get into blocks of data to send/receive to the FT245BM.
    FTDI have made USB interface easy since they provide free drivers and
    an API for talking to the FT245BM. This takes the pain away from
    software development, and appears to be almost easier than programming
    the legacy PC parallel port under Windows.
    Adam
  2. Nico Coesel
    Nico Coesel Guest
    You could modify a soundcard because it's ADC/DAC will also do fine
    with DC signals. Remove the DC blocking caps and make a new
    input/output circuit with a few opamps as amplifiers/buffers.
