N
Noozer
I'm looking at building a couple circuits and have some questions regarding
LEDs...
#1:
I've been given the following formula to figure out what size current
limiting resistor to use when working with LEDs:
R = ( Vs - Vl ) / I
So, if I want to power a 3v, 20mA LED from a 12v source (such as an
automobile) I would simply need to use a 470K (closest value to 450)
resistor? Do I need to worry that my source is 12v and the LED is only 3v?
450 = ( 12 - 3 ) / .02
#2
How does one determine what wattage resistor to use as a current limiting
resistor?
Using the above example, would it be 12v * 20mA = .24 watt?
#3
I know that putting LEDs in parallel is bad. If I put LEDs in parallel, and
ensure that each LED has it's own current limiting resistor it should be
fine, right? Same for strings of LEDs?
In other words, if I want to light 25 LEDs, can I string five LEDs together
in series with a single current limiting resistor, and repeat that four more
times in parallel?
LEDs...
#1:
R = ( Vs - Vl ) / I
#2
resistor?
#3
times in parallel?
