E
Ecnerwal
APC...Automatic Power Control
Lots of complex hoo-ha out there for this. I'm trying to simplify, using
the LM317 since I like it and have them on hand. Costs a few cents more
than a transistor solution, but low component count and built-in
protection, as well as supply voltage range are nice. Plus I already
have one in use for the dumb (constant current, non-APC) version of this
circuit.
Laser Diode has a photo-diode in the same package. Point of APC circuits
is to pay attention to the photo-diode output and adjust laser current
to maintain consistent photo-diode output. Common positive for the parts
I'm playing with.
L In---V+
M
3 Out--------
1 +
7 Adj |---|---|
| _P V L
| ^D - D
| R6000 RX
My (too) quick think through this is that if RX is set to provide
adequate reverse bias to the PD (30 max, 5 suggested) in the realm of
operating current (80-100 ma), the 6000 ohm should result controlling at
a 0.2mA photo-diode current. ...But that ignores voltage across the
photo-diode, and the fact that the only voltage the photo-diode will see
is the 1.2V from Out to Adj. Crap. That won't work.
OK, turn it around and use the LM337. Adj terminal only sees the voltage
across the 6000 ohm resistor now. RX wastes power (under half a watt?)
to get photodiode reverse voltage up, at least I think that works. 47
ohms should about work, given a mid-range current of 90 mA, laser diode
forward voltage of about 2V, and drop across R6000 of 1.2V.
_P V L -
^D - D
| R6000 R47
L Adj |
M |
3 In---V- |
3 |
7 Out-----------|
Please poke holes in this, if there are holes to be poked. I'll try
building it shortly if it's not hopelessly flawed.
....and yes, I know it's much cheaper/simpler to just buy a built diode
and APC circuit. That's not the point here. The intellectual exercise
with a semi-practical result is the point.
circuit.
I'm playing with.
L In---V+
M
3 Out--------
1 +
7 Adj |---|---|
| _P V L
| ^D - D
| R6000 RX
_P V L -
^D - D
| R6000 R47
L Adj |
M |
3 In---V- |
3 |
7 Out-----------|
