simple HF Signal
Discussion in 'General Electronics Discussion' started by newbee2014, Jul 9, 2014.
  1. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Hello all.
    I'm learning how HF signals work.
    I just want an emitter who sends a wave (30mhz)to a receiver.
    So I wanted to know if my schema is right.
    And how to make the receiver part please?.
    Thank you all.
  2. davenn
    davenn Moderator
    13,647
    1,884
    hi
    welcome to EP :)
    without knowing the model of the ceramic resonator, I cannot guarantee that that's the way it can be connected
    Do you have the part number for it ?
    cheers
  3. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Dear Dave.
    Someone just told me it won't work with it.
    I just found out this,I will build it.
    Apparently it's a 90MHz transmitter.
    But I can't find any 90MHz receiver.
    Can you help me please.
    Thanks.
  4. davenn
    davenn Moderator
    13,647
    1,884
    90MHz receiver ..... your FM band receiver they all go from 88 - 108MHz ;)
    if you haven't got ... go buy a $5 AM/FM radio
    a lot of mobile phones also have a FM band receiver
  5. davenn
    davenn Moderator
    13,647
    1,884
    just as a side thing for you to learn ....
    If you are going to start playing with electronics ... its important to get your designations correct
    note how I corrected your post :)
    MHz not mhz
    just one of many things for you to learn .... it saves confusion
    M for Mega ..... m for milli
    Hz for Hertz .... as it was named after Mr Hertz
    cheers
  6. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Dear Dave.
    You are right!..interferences.I need less than 90.
    "The frequency is determined by the 6 turn coil. By moving the turns together, the frequency will decrease. The circuit transmits at 90Mhz. It has a very poor range and consumes 16mA".
    Now I need to build a receiver,maybe a 80 or 70Mhz.
    Thanks.
  7. davenn
    davenn Moderator
    13,647
    1,884
    I don't think you understood
    If its supposed to work at around 90MHz, leave it there.
    you can tweek the coil a bit if there is a local FM radio station at around 90MHz
    did you not read this bit ?.....
    BUY a $5 AM/FM radio for your receiver
    cheers
  8. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Dear Dave.
    I need to build it.
    Thanks.
    PS:90Mhz is the number 1 rap radio in France,I don't want to spoil it.
  9. (*steve*)
    25,411
    2,779
    Don't worry, you'll probably improve it.
  10. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    90 MHz is just an approximate frequency. You can tune your receiver to somewhere where there's nothing transmitting, then tune your transmitter to match.
    Is your transmitter an FM transmitter? If it's AM, an FM radio won't receive it very well.
  11. davenn
    davenn Moderator
    13,647
    1,884
    Its just an oscillator, Kris, it's unmodulated
  12. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Dear friends.
    I built it,took my radio switched to 90Mhz.But nothing happened.
    I think I have an issue with the size/diameter of the coil.
    "then tune your transmitter to match."
    Where I do that? reducing the 6turn coil?how much I need?.
    Thanks.
  13. davenn
    davenn Moderator
    13,647
    1,884
    it may not be exactly 90MHz you need to tune around on the radio carefully to find where the background hiss gets quieter
    (assuming that the oscillator is resonating somewhere in the 88-108MHz band)
    if you do find where the hiss gets quieter, then switch off the transmitter and see if the hiss comes back
    ( when I want to find what freq a transmitter if on, I use a frequency counter. Else it is VERY difficult to know what is happening)
    cheers
  14. newbee2014
    newbee2014
    6
    Jul 9, 2014
    Didn't work.
    I'm sure the issue is the coil.
