simple graph drawing software needed
Discussion in 'Electronic Design' started by Mebart, May 24, 2005.
  1. Mebart
    Mebart Guest
    I need some software for drawing basic graphs on a pc. Needs to do
    linear, and log-log. I want to be able to enter data points manually
    or from a mathematical formula. I don't need fancy features and lots
    of bells and whistles. Hopefully, it's free or nearly so.
    M
  2. Excel will draw graphs of groups data points. I'm sure OpenOffice does
    similarly.
  3. Tim Wescott
    Tim Wescott Guest
    Yes, OOo does just fine at that, and you can cut and paste the graphs
    into other OOo documents.
  4. Some good key words for Google: mathematics graphing software freeware
    For instance:
    http://www.gold-software.com/education21-40.html
  5. Mark Zenier
    Mark Zenier Guest
    There's gnuplot.
    Mark Zenier Washington State resident
  6. Mebart
    Mebart Guest
    I can't afford Excel, and Im not sure it does log-log or even
    semi-log.
    Tell me about 'OpenOffice' though. WHat is it and where can I get it?
    M
  7. I convinced it to do semi-log before I posted earlier. I'm not sure
    about log-log, but It's worth some playtime.
    It's free. What else do you need? ;-)
    http://www.openoffice.org/
  8. peter
    peter Guest
    Keith Williams a écrit :
    Hello.
    Just use Excel's math functions to create new series in log scale (or
    not) and plot these.
    Excel might not be the simplest software for your needs, but it shure
    does a lot of things.
    Somewhat simpler to use : GNU Plot (free) or Origin (relatively expensive)
    Peter
  9. Bob Monsen
    Bob Monsen Guest
    gnuplot, coupled with octave.
  10. Get a cheap secondhand beige-coloured Mac (G3 or lower), which should
    come with a free copy of Claris Works. Although intended as an office
    package, that will do everything you need and includes useful serial
    port comms too.
  11. MSC
    MSC Guest
    Ooookay. And that's better than downloading some free software in what
    way?
    Mike
    P.S. Any relation to Peter?
  12. gnuplot
    robert
  13. It's a full-blown free office suite developed by Sun that runs on
    Windows, Linux, and lots of other Unices. It exports and imports
    MS Office formats (and a lot of others). It's own "native" data
    format is essentially gzipped XML, and of course is exchangeable
    between different platforms.
    It's quite a bit slower than MS Office (probably because of the
    somewhat braindead XML/Java base), but that doesn't matter with
    today's hardware.
    robert
  14. ....except the OP specifically stated that he can't afford Excel.
    But Openoffcice's "calc" module is pretty compatible.
    robert
  15. It's better if the questioner happened to have easy access to an older
    Mac (or was already using one but hadn't made that clear) and hadn't yet
    realised the strength and range of the software that comes bundled with
    them.
    It might also be useful as an alternative approach if, for any reason,
    the other suggestions don't give satisfactory results.
    I didn't offer it as the unequivocal 'best' solution - but it is a valid
    approach that hadn't yet been mentioned and I do know it will work.
    Not that I'm aware of.
  16. Mebart
    Mebart Guest
    OK, thanks all.
    I got open office and can't figure out how to get started. There's a
    lot of stuff in there. How do I get started with openoffice?
    Had no luck with gnuplot. I finally figured out where to download it
    and got a 2 mb gzip file. I opened the archive and it has many files
    in it, including alot that had 'readme' filenames. But, none of them
    would open in windows(XP). So, I have the zip file on my desktop, but
    have no idea how to proceed. I see some of the file extensions are .c.
    Is this supposed to be a source file that you have to compile???
    Regards
    M
  17. Rich Grise
    Rich Grise Guest
    Have you read this page?
    http://www.openoffice.org/dev_docs/instructions.html
    If it's got .c files and a "lot of" READMEs, then it's source, and
    probably useless if all you have is XP with no c compiler.
    You should download gp400win32.zip . I found a copy at
    ftp://ftp.gnuplot.info/pub/gnuplot/gp400win32.zip .
    It has wgnuplot.exe, which would be the executable, and wgnuplot.hlp,
    which would be the help file.
    When you unzip it, it should create its own dir. structure under
    [where the zip is]\gnuplot, then just cd to gnuplot\bin and give it a
    shot. :) Well, read the READMEs first. They're ordinary text files -
    you can open them with NOTEPAD.exe .
  18. Mebart
    Mebart Guest
    Thanks Rich, that was easy.....
    Almost all of the chatter there was about compiling, I really never
    happened to stumble upon the executable link and was wondering if it
    was for real:>:
    Regards
    M
  19. Mebart
    Mebart Guest
    Hey, now I'm cooking! Got gnuplot, don't even understand half the
    terms in the help file though:>: Math was never my strength.
    But, it runs and I can cut and paste examples from the examples help
    page and it plots them.
    I'm trying to plot y=ax^b, for all values of x between 1200 and 200
    with b=7.64 and a=1.170, with at least 100 data points. Do I have to
    tell it to plot this on a log-log scale or is this done automatically
    because I used x^b in the formula?
    What's the complete command for this???? I'm looking for a mailing
    list for gnuplot, it seems like a very nice program.
    M
  20. Mark Zenier
    Mark Zenier Guest
    Here's an example that runs under gnuplot 3.7.1. It's the
    inductive/capacitive reactance plot vs. frequency that's in The Art of
    Electronics/Terman/ARRL Handbook. In other words, a log/log plot
    of 1/2*pi*f*c and 2*pi*f*l. I'll be damned if I can remember
    what all this stuff does besides spit out a page of postscript.
    Basically, I went down the list of commands and put them all in
    and adjusted them until it looked good.
    set terminal postscript landscape monochrome "Helvetica" 14
    set output 'react.ps'
    set title "reactance vs. frequency" 0,0
    set noclip points
    set clip one
    set noclip two
    set border
    set boxwidth
    set dummy x,y
    set format x "%6.3g"
    set format y "%g"
    set format z "%g"
    set grid
    set nokey
    set nolabel
    set noarrow
    set nologscale
    set logscale x 10
    set logscale y 10
    set offsets 0, 0, 0, 0
    set nopolar
    set angles radians
    set noparametric
    set view 60, 30, 1, 1
    set samples 100, 100
    set isosamples 10, 10
    set surface
    set nocontour
    set clabel
    set nohidden3d
    set cntrparam order 4
    set cntrparam linear
    set cntrparam levels auto 5
    set cntrparam points 5
    set size 1,1
    set data style points
    set function style lines
    set xzeroaxis
    set yzeroaxis
    set tics in
    set ticslevel 0.5
    set ytics (1,2,3,5,7,10,20,30,50,70,100,200,300,500,700,\
    1000,2000,3000,5000,7000,\
    10000,20000,30000,50000,70000,100000)
    set xtics (100,"" 200,300,"" 500,"" 700,\
    1000,"" 2000,3000,"" 5000,"" 7000,\
    10000,"" 20000,30000,"" 50000,"" 70000,\
    100e3,"" 200e3,300e3,"" 500e3,"" 700e3,\
    1e6,"" 2e6,3e6,"" 5e6,"" 7e6,\
    10e6,"" 20e6,30e6,"" 50e6,"" 70e6,100e6)
    set ztics
    set notime
    set rrange [-0 : 10]
    set trange [-5 : 5]
    set urange [-5 : 5]
    set vrange [-5 : 5]
    set xlabel "Hertz" 0,0
    set xrange [100 : 1e+08]
    set ylabel "Ohms" 0,0
    set yrange [1 : 100000]
    set zlabel "" 0,0
    set zrange [-10 : 10]
    set autoscale r
    set autoscale t
    set noautoscale
    set autoscale z
    set zero 1e-08
    set label "10H" at 200,30000
    set label "100mH" at 1500,3000
    set label "1mH" at 20000,300
    set label "10uH" at 200000,30
    set label ".1uH" at 2000000,3
    set label "1H" at 600,8000
    set label "10mH" at 5000,1000
    set label "100uH" at 50000,100
    set label "1uH" at 600000,8
    set label "100uF" at 2e2,4
    set label "1uF" at 2e3,40
    set label "10nF" at 2e4,400
    set label "100pF" at 2e5,4e3
    set label "1pF" at 2e6,4e4
    set label "10uF" at 6e2,13
    set label "100nF" at 6e3,130
    set label "1nF" at 6e4,1.3e3
    set label "10pF" at 6e5,1.3e4
    xl(x,l) = 2*pi*x*l
    xc(x,c) = 1/(2*pi*x*c)
    plot \
    xl(x,5) not w l 2,\
    xl(x,.5) not w l 2,\
    xl(x,.05) not w l 2,\
    xl(x,5e-3) not w l 2,\
    xl(x,5e-4) not w l 2,\
    xl(x,5e-5) not w l 2,\
    xl(x,5e-6) not w l 2,\
    xl(x,5e-7) not w l 2,\
    xl(x,5e-8) not w l 2,\
    xc(x,50e-6) not w l 2,\
    xc(x,5e-6) not w l 2,\
    xc(x,.5e-6) not w l 2,\
    xc(x,50e-9) not w l 2,\
    xc(x,5e-9) not w l 2,\
    xc(x,.5e-9) not w l 2,\
    xc(x,50e-12) not w l 2,\
    xc(x,5e-12) not w l 2,\
    xc(x,.5e-12) not w l 2,\
    xl(x,10) w l 1,\
    xl(x,1) w l 1,\
    xl(x,.1) w l 1,\
    xl(x,.01) w l 1,\
    xl(x,.001) w l 1,\
    xl(x,1e-4) w l 1,\
    xl(x,1e-5) w l 1,\
    xl(x,1e-6) w l 1,\
    xl(x,1e-7) w l 1,\
    xc(x,100e-6) w l 1,\
    xc(x,10e-6) w l 1,\
    xc(x,1e-6) w l 1,\
    xc(x,100e-9) w l 1,\
    xc(x,10e-9) w l 1,\
    xc(x,1e-9) w l 1,\
    xc(x,100e-12) w l 1,\
    xc(x,10e-12) w l 1,\
    xc(x,1e-12) w l 1
