L
Lionel
Per the subject line. I want to experiment with direct PAL video
generation from a microcontroller, with the minimal number of parts.
I'm thinking that a good starting place might be to use a CPU clock
that's based on the PAL subcarrier frequency (4.43MHz) multiplied with
a PLL+VCO+Divider to give me phase reference points, & directly
generate the composite colour signal via an R2R ladder.
So, some questions:
1) Is this a reasonable concept? (I'm comfortable with per-cycle level
timing & coding)
2) Any tips/suggestions/thoughts as to a better approach?
3) What's a good (simple, cheap, stable) circuit to oscillate a
standard 4.43MHz PAL sub-carrier xtal? (Ideally just an inverter or
two)
4) Suggestions for a cheap + simple PLL frequency multiplier (x8? x4?)
for the above to give me multiple cycles per PAL subcarrier cycle?
5) How many analog samples do you actually /need/ to generate per
subcarrier cycle to get good quality PAL colour?
6) Any recommended online resources/references that cover direct
digital synthesis of medium to high quality PAL colour video?
Thanks in advance for any help or advice.
So, some questions:
timing & coding)
two)
