C
CampinGazz
Firstly, from my last posts you can prolly gather I can build a circuit if a
circuit diagram is available, I just need help getting to that stage with
what components to use and how to connect them...
For my next project, I have a load of woodworking tools I'm going to be
using for the next 3 months as I build a motorhome, they are mainly small
tools, router, sanders, biscuit joiner etc, plus a bandsaw and a table saw,
I have an old vacuum cleaner I'm going to use for collecting the dust
produced by the tools in use, but it's a pain to have to keep switching it
on and off before and after I use the tools,
So I want something like a 2 way extension lead, plug the tool in one
socket, and the vacuum in the other socket, when the tool is turned on, the
vacuum starts up, tool off, vacuum off.
I know you can buy vacuum cleaners that have this function built in, but
they're not cheap, and I already have the vacuum I want to use, also they
usually have a limit of 1800 watts for the tool plugged into them.
The table saw pulls 2500 watts or there abouts, it's an induction motor, so
will have a much higher start up current, (were on 230 volts here)
So I imagine with the vacuum cleaners with the power take off built in, they
use something in series with the tool to be used?
What can I use that doesn't limit the power of the tool that switches the
vacuum? vacuum motor is 1200 watts.
The smallest tool I'll use pulls 30 watts, largest pulls 2500 watts,
Should I be looking at something like a ammeter type circuit using a pass
through coil to detect the current to switch a suitably sized mains relay
(not sure of the terminology there, but not using a shunt, inductance
measuring of the current? like a clamp meter does), or should I be looking
at a high current triac?
Ideally I'd like something that doesn't have to pass the power of the tool
through it to switch the vacuum, so I could use it with other things that
need something turned on when another item starts up.
