Simple circuit for RS232 > 12 bit DAC?
Discussion in 'Electronic Basics' started by BR, Oct 3, 2003.
  1. BR
    BR Guest
    Any schematics of this? I want to control only one motor from a PC. What I
    need is high resolution control of velocity. Position isn't necessary. The DAC
    will connect to the control voltage input of an H-bridge that has a built-in
    PWM generator. The motor is a small Kollmorgen Servodisc.
    Ben
  2. Bob Masta
    Bob Masta Guest
    How about the parallel port instead? If you are running under
    DOS (so you can write directly to the port) you can use a simple
    R-2R ladder. You might need to buffer the digital outputs on
    some ports if their levels aren't uniform on all bits. If you only
    use the data out port you just have 8 bits, but you can also
    use the control port to get another 4 if you're careful. (The
    control port bits will almost certainly need buffering since they
    have pull-ups.)
    For the 8-bit version you can check out the LPTX driver
    Help files for my Daqarta system at
    www.daqarta.com/lptx.htm
    This discusses using the port for analog in and digital out
    as well as analog out, so read through for the DAC section.
    Hope this helps!
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
  3. John Fields
    John Fields Guest
  4. BR
    BR Guest
    Thanks Bob. I later realized how slow the serial port is. I forgot to check
    this thread and started another. Looked around and found a 12 bit DAC such as
    the MAX508. Should make it easier (I think) to get going since its interface
    is a byte wide (8+4). But for starters it'll be an 8 bit DAC or a R-2R ladder
    as the experiment may work with that resolution.
    A control port will be used for the foward/reverse ports on the H-bridge.
    Ben
  5. BR
    BR Guest
    John, I made the mistake of considering RS232 as it's too slow. It'll be via
    parallel port. What is an all-hardware solution? I'm using Quickbasic on an
    old 133 machine. Just a bunch of loops to change velocity and will need to
    edit those values frequently. If the experiment (fluid study) shows a result,
    the program can be run again to repeat the result. It would be ideal to
    manually control motor speed with a pot and ADC (looking for certain fluid
    activity) while writing control data to disk, and then later playback the
    data. But this would be a little ahead of myself at this stage. Bet Quickbasic
    sucks for that.
    Ben
  6. John Fields
    John Fields Guest
    At 9600 bits per second you can accumulate 12 bits in 2.083ms, including
    the overhead of the RS-232 start and stop bits and the wasted four bits
    of data, so that's doesn't seem too shabby for a motor control
    application!-)
    For RS-232, basically a comparator or something like Jim Thompson's
    MC1489,(just thought I'd mention it to save him a post!^) or one of the
    zillion chips Maxim's got to change the bipolar RS-232 signal into a 0
    to 5V logic signal, two 8-bit shift registers, a clock, some glue logic
    and your DAC or R-2R ladder.
    For the parallel port, it's a couple of HC373's or 375's and your DAC
    or R-2R ladder and probably a little glue logic if you can't control the
    registers with the port's control pins.
  7. BR
    BR Guest
    It depends on what you want to control. Might as well go with SPP being
    50Kbytes/sec or better. The more throughput, the smaller the steps can be
    during fairly rapid changes in velocity. I ordered a surplus S6M4H servodisc
    "pancake" because it's a DC brushed type with zero cogging. It's design is
    amazing to me.
    http://kmtg.kollmorgen.com/products/product_literature/product_brochure/pdfs/KOL1037.pdf
    They do have zillions and ran into a 12 bit DAC with byte wide loading, like
    MAX508. Didn't know they made them. Maybe easier to use?
    http://pdfserv.maxim-ic.com/en/ds/MAX507-MAX508.pdf
    It's been a while since I've looked into this stuff and really need to move
    beyond the CMOS 4000 series :)
    Tanks
    Ben
