Simple capacitor question
Discussion in 'General Electronics Discussion' started by Mustwin351, Sep 12, 2014.
  1. Mustwin351
    Mustwin351
    49
    Apr 10, 2013
    When you have a capacitor between your two inputs on an alternating current circuit (i.e. possibly a power supply) why does that not create a direct short?
    What am I missing? If a capacitor passes ac voltage why is that not like a line to line short?
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    A capacitor can appear as anything from a short to a very high value resistor depending on the frequency and capacitance.
    There is a formula for it...
    Xc = 1 / (2*Pi*f*C)
    Xc = Capacitive reactance (Ohms)
    Pi = 3.14159.....
    f = Frequency (Hz)
    C = Capacitance (Farads)
  3. davenn
    davenn Moderator
    13,799
    1,940
    A capacitor doesn't pass AC as such .... as in NO current flows directly between the 2 plates
    Rather each plate alternately charges and discharges
    And as Gryd3 said, it will "act" as a short circuit dependant on the info he gave above
  4. Mustwin351
    Mustwin351
    49
    Apr 10, 2013
    Thanks guys I recall that now.
    For a power supply the capacitor goes on the "dc" side or the circuit and no matter the reactance of the cap you won't have a short. Instead it just "charges" the capacitor.
    It's been sometime since school. Thank you.
  5. davenn
    davenn Moderator
    13,799
    1,940
    The capacitor after the rectifier smoothens out the AC to something that resembles a DC voltage ( but with ripple (the remaining AC))
    Have a look here and ask about anything you have a problem understanding :)
    http://www.learnabout-electronics.org/PSU/psu12.php
    cheers
    Gryd3 likes this.
  6. Mustwin351
    Mustwin351
    49
    Apr 10, 2013
    Great link Dave. Thanks!
    It states that in order to use a bridge rectifier for full wave rectification that a center tapped transformer must be used...but it then refers to figure 1.1.3 for this which does not have a center tapper transformer.
    Is this just a mistake in figure 1.1.3?
    http://www.learnabout-electronics.org/PSU/psu11.php
  7. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    This is certainly a mistake ;)
    The Label for each image is below the image, not above :p
    You are looking at figure 1.1.4 The Bridge Rectifier that has no center tap and 4 diodes.
    Figure 1.1.3 certainly does have a center tap on it's secondary and is using two diodes.
  8. Mustwin351
    Mustwin351
    49
    Apr 10, 2013
    So figures:
    1.1.4
    1.1.5
    1.1.6 should all have center taps on the transformer secondaries connected between the two diodes correct?
    I guess without a center-tapped transformer the best you can achieve is half wave rectification?
  9. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Nope.
    1.1.4
    1.1.5
    1.1.6
    Are all using a Bridge Rectifier which does tot require a center-tapped transformer secondary.
    1.1.3
    Is using 2 diodes, and requires a center-tapped transformer secondary to rectify a full wave.
    This was a misunderstanding. The page correctly refers to figure 1.1.3 which had 2 diodes and a center-tapped transformer, but you had accidentally looked at 1.1.4 instead which is the first figure to use a bridge rectifier.
  10. Mustwin351
    Mustwin351
    49
    Apr 10, 2013
    I gotcha now. Sorry a little further reading would have helped. The center tapped transformer with a rectifier is just more efficient than one without a center tap.
    Thank you very much!
  11. davenn
    davenn Moderator
    13,799
    1,940
    you still might be misunderstanding ... the way you just wrote that is misleading and not what the www page said ;)
    they said ....
    they are telling you its more efficient that a single winding transformer and only ONE rectifier diode as referenced to in Fig 1.1.2
    A single winding secondary and a bridge rectifier is still efficient. and has the advantage of full wave rectification without the need for a centre tapped secondary :)
Similar Threads
Loading...
