Simple analog to digital conversion??
Discussion in 'Electronic Basics' started by [email protected], May 19, 2007.
  1. Guest
    Hi all,
    I'm looking for the *simplest* way to convert a 3-state analog input
    (-5V, 0V, or +5V) into a 2-channel TTL output, as shown in the
    following truth table:
    Input Out 1 Out 2
    -5V L H
    0V L L
    +5V H L
    I'm a noob and have come up with a pretty convoluted way to do this,
    but I'm not sure how to do it with a single chip-- it seems simple
    enough. Any suggestions?
    Thanks in advance!
  2. Puckdropper
    Puckdropper Guest
    wrote in @o5g2000hsb.googlegroups.com:
    Have you considered looking for a chip to do this for you? You may want
    to check out something like the semiconductor reference guide that Radio
    Shack had available at one time.
    I'd probably start with a couple diodes and a NOT gate. (For 5V
    magnitude voltages, output1 & output2 are NOTted.)
    Puckdropper
  3. Chris
    Chris Guest
    Hi, Vogelito. The classic solution is to use a dual comparator IC to
    compare the input voltage with a reference, and output a digital logic
    signal. This circuit will fulfill your 1 IC requirement, but will
    also require some resistors (view in fixed font or M$ Notepad):
    | VCC
    | + VCC
    | VCC | +
    | | | |10K .-.
    | .-. | | VCC | |10K
    | 10K| | '-' + | |
    | | | | |\| '-' VCC
    | '-' o-----|-\ | +
    |Vin ___ | | | >--o |
    | o-|___|-o----)--o--|+/ 1 .-.
    | 10K | | |/ | |10K
    | .-. | LM393 | |
    | 20K| | | |\ '-'
    | '-' | >------o
    | | .--|+/ 2
    | o-- |/|
    | .-. GND
    | | |10K
    | GND
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
    The two input resistors change the -5V/0V/5V input into a 0V/2.5V/5V
    input, which allows you to use a single power supply for the LM393
    dual comparator. The two 10K and 20K resistors set the logic level
    changes at 1.25V and 3.75V, halfway between the input levels. The two
    10K resistors at the outputs of the comparators are necessary to
    ensure logic level outputs for TTL, CMOS and all other +5V logic
    families.
    Here's the datasheet on the IC:
    http://www.national.com/ds.cgi/LM/LM193.pdf
    Good luck with your homework
    Chris
  4. JeffM
    JeffM Guest
  5. Jamie
    Jamie Guest
    you need a window type comparator.
    this is basically 2 voltage comparators using the same
    input signal.
    one is driven via the - input and the other is driven
    via the + input.
    a common reference voltage is used to bias the remaining
    inputs of each comparator.
    etc..
    LM311 is a comparator that may help you there.
    Just put a couple of them together.
    You can also use an old standby LM339 which has
    open collector outputs..
  6. default
    default Guest
    Window comparator is the obvious choice with a single quad comparator
    chip or op amp to do that.
    But what happens if your output is +/- 2.5 volts or exceeds 5 volts?
    Do you care about that? If so, it gets more complicated.
