P
[email protected]
And probably more accurate than the spray can of cheese whiz in my
fridge...and about as relevant.
The 555 is the carrier. All it has to do is stay in the bandpass of
the receiver. So, the real question is, "what are the receiver
requirements for carrier accuracy and stability?" I'm betting that the
$19 WWVB atomic clock hanging on my wall has a pretty sloppy receiver.
While I'm at it, let's ask one more relevant question...
WHEN does the watch update itself. I'm just guessing that the power
consumption of the WWVB receiver might be orders of magnitude greater
than the power consumption of the part that goes tick-tock.
That suggests that the receiver might be OFF most of the time.
Won't help to have a synchronization setup that's not near
when the watch is listening. And what if it can't find a signal?
Does it retry? How often? Does it ever give up and quit trying
altogether? Battery drain may go through the roof. Or it may just
stop trying to synchronize.
Knowledge of the update algorithm might be critical here.
When set to automatic the watch tries to update at midnight, if that
fails it tries again at 1, 2, 3, 4 and 5 AM. It will do this every
night if set to auto. You can also perform a manual receive at any
time. Battery drain is not an issue as watch is solar powered. Worth
noting the watch also a has 3 bar "receiving indicator" which I hoped
to be able to use to verify my transmission is working before I start
to encode it.
I have the oscillator running, and the scope and meter say 60.0 KHz,
which I hope would be accurate enough for reception. So far the watch
doesn't show any signal strength on the receiving indicator though.
Problem is I don't know if that means I am not successfully
transmitting anything, or that the watch is simply not seeing valid
time data...
The whole project is silly. If you've got a wrist watch that cost over
$9.99 and needs to be set more than once a year, it's broke. Take it
back. If you need action on a schedule that accurate, you need
something more reliable than a human with an accurate watch
to orchestrate it.
But who among us has never delighted in a project that others
thought a waste of time?
"Need" is mentioned there a lot, I never said I "needed" to update my
watch this way. That doesn't mean I don't enjoy trying, or wouldn't
thoroughly enjoy being able to.
Sean
