Sim card extension socket
Discussion in 'General Electronics Discussion' started by bowlingo, May 2, 2012.
  1. bowlingo
    bowlingo
    40
    Jun 29, 2011
    Hello,
    I have one of these (along with lots of other bits and pieces)
    http://www.coolcomponents.co.uk/catalog/module-p-714.html
    It is currently inside a large box
    On one side of the board there is a up and over sim card socket.
    I am looking for hopefully something off the shelf that will allow me to plug one end into the existing sim card socket and panel mount the other end on the outside of the box so the user can change the sim card easily without having to open the lid of the box and poke around inside.
    Anyone any ideas?
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Should be as simple as getting a sim card socket and wiring it 1 for 1 with the one that is already on the board...
    From the same site you linked, looks to be only 6 wires...
    http://www.coolcomponents.co.uk/catalog/socket-p-224.html
    If you want something already done Google or Ebay, 'sim card extender' and you will find a nifty little flexible flat cable that drops right into the existing sim socket and has a new socket on the other end...
  3. bowlingo
    bowlingo
    40
    Jun 29, 2011
    In theory that is correct....
    The trouble is I need some kind of robust mounted socket so the user can slide the sim through the outside of the case
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Sim card and robust are contrary...
    Unless you want to design your own socket you are going to have to accept the fact they are not real robust...
    Get a 'sim card breakout board' then the socket will at least be mounted to a PC board you can affix to the wall or whatever...
  5. bowlingo
    bowlingo
    40
    Jun 29, 2011
  6. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    That is because it's an sim adapter/converter not a sim extender...
