Silly power loss question
Discussion in 'Electronic Basics' started by Pete D, Apr 15, 2007.
  1. Pete D
    Pete D Guest
    I am PWMing a solar panel output or open circuit 36V to charge 2 lead
    acid batteries in series to 27.6V and I am trying to decide how much
    power is being dissipated by the switching FET. Is it relatively low
    because when the output is off there is no power loss in the fet and
    when the output is on there is only the current squared*the internal on
    resistance of the fet and the average power is equal to the average
    mark/space ratio. Or as the output is going through a low pass filter is
    the power equal to the averaged volt drop across the FET squared divided
    by the on resistance of the fet
    i don't think I have explained wqhat I am asking well at all, but cannot
    think how better to put it?
    TIA
    pete d
  2. Phil Allison
    Phil Allison Guest
    "Pete D"
    ** With a fixed resistance, the power dissipated is always given by the rms
    value of the current or voltage across that resistance. Your method of
    calculating the on time power and then scaling it by the duty cycle is fine.
    Only time average current value comes into play is for calculating the
    amount of energy delivered to the battery.
    ......... Phil
  3. Eeyore
    Eeyore Guest
    You're also ignoring switching losses as the FET turns on and off. It spends a
    brief period in linear operation each time it turns on and off..
    Graham
  4. Pete D
    Pete D Guest
    thanks, that's what I hoped was the case, I can do with a relativly
    small heatsink in this case then, ta muchly;-)
    pete d
  5. Pete D
    Pete D Guest
    Ah, right, that sounds hard to calculate;-)
    I'll allow for 20% extra and see how hot it gets.
    Thanks both.
    pete d
