S
Spehro Pefhany
Hi, all:-
I'm in the process of designing relatively high-precision signal
conditioning and data acquisition system front end.
It's desirable to have some kind of gain/range switching to maximize
the dynamic range over different operating modes.
Available options for switching are ADGxxx type analog multiplexers
(voltages are relatively high.. say +/-15V so HCxx are out) or "2A"
telecom style signal relays as are quite commonly used in bench-top
instruments.
All the relay data sheets that I've looked at have disturbingly high
recommended minimum voltages/currents. Say 10uA or 100uV-10mV (usually
the latter). I'd prefer to have just 10-20pA or so at < 1uV. With some
compromise I could arrange to have 10uA flowing through the contacts,
but that would result in a (possibly variable) ~1.5uV voltage drop. If
it varied with vibration that would be Bad. There's a reference to
some with special Silver-Palladium contacts for low-level loads, rated
at 10mA max, but I see no availability.
Any actual experience with these things? It might be possible to
"exercise" the contacts occasionally, or just before a measurement.
Also, on the ADGs, the typical leakage on the best ones is in the 10's
of pA (according to the data sheets, I have not yet made any
measurements). Any experience on the effects of long term radiation?
Usually things get worse, but how much worse?
Also a bit worried about the "sealed" relays in low pressure.
Thanks for any info,
Best regards,
Spehro Pefhany
instruments.
Best regards,
Spehro Pefhany
